RAM 1500 TRX 23in Light Bar - PRO from M&R Automotive
MandRautomotive
Burbnk, CA
Fits 2021 2022 2023 2024 2025 RAM 1500 TRX
  • Curved LED light bar PRO
  • Fits in the factory opening between the grille and bumper
  • Slim and sleek, built in look
  • Metal bracket is powder coated black
  • Must remove grille, but don't need to remove the bumper
  • No cutting or drilling required. The kit is a complete bolt on using factory openings and hardware.
  • Doesn't interfere with radiator air flow
DUAL COLOR
Main White LED Light with Amber DRL (daytime running lights)
  • White LED -- Super bright and crisp white beam pattern. It will definitely provide you with enough light needed for all of your adventures. However, these are only for off-roading and can’t be used on the regular road. They will blind the in-coming traffic and also violates road safety.
  • Amber DRL -- amber DRL “daytime running lights” acts purely for aesthetics. Since it doesn’t give out much light, you can use this amber DRL feature on regular roads, it doesn't blind in-coming traffic.
Introducing our new LED light bar-PRO wiTh a unique appearance and optimal performance.
  • Combo Pattern: combined spot and driving optics offers a balance between the distance and width
  • Uses TIR (Total Internal Reflection) lens is different from our the regular slim light bar. The TIR lens collects all of the light from the LED and directly leads them to where you need, drastically reducing glare and improving total efficiency.
  • Higher light efficiency: brighter, longer irradiation distance
  • Housing is upgraded to 304 aluminum. The surface is UV polyester powder coated to prevent against UV, salt water, corrosion, fading and scratch resistant.
  • Equipped with thermal management system that automatically adjusts the brightness output according to the external temperatures
You can get more information on this RAM TRX light bar here
Leonette
