Superchips Dashpaq+ tuning for TRX +38hp and+28ft-lbs torque to the tires
For those of you looking for more power out of your TRX!
For true Ram Hemi enthusiasts, the term ‘enough power’ isn’t in their vocabulary and the all-new Ram TRX proves that. While 702-horsepower from the factory seems quite enough, Dashpaq+ takes the TRX into new territory with +38hp and+28ft-lbs torque to the tires! Superchips tuning calibrations have been fine-tuned for both 91 and 93 Octane and improved throttle response, transmission shift strategies, boost curves, and overall power delivery for impressive street manners.
Dashpaq+ offers state-of-the-art in-cab monitoring with an intuitive color touchscreen with WIFI for easy updates. Dashpaq+ for TRX offers two tuning calibrations and the ability to change multiple vehicle features without ever opening the hood or breaking a sweat. Like all other 2015+ Chrysler vehicles, the factory PCM must be replaced with an unlocked PCM, which is handled through an easy PCM swap process to limit vehicle downtime and out of pocket expense. The TRX will also require a Gateway Bypass module be installed, this module is included with device purchase.
Features
  • Color Screen
  • Color Touch Screen Display
  • Screen Auto-Dim
  • Compatible with Expandable Accessory System (EAS)
  • Alerts and Records
  • Performance tests
  • Speedometer Correction
  • Tire Size - 20-44
  • Shift Points - Superchips Optimized
  • Shift Firmness - Superchips Optimized
  • Speed Limiter - Enable/Disable
  • Rev Limiter - Y
  • Adjust Fan - 150-230
  • DTC Read & Clear
  • Internet Updateable
  • 93 Octane 38HP 28TQ
  • 91 Octane 30HP 24TQ
  • WiFi Updates - Y
  • Touch Screen - Y
  • Torque Management Adjustment - Superchips Optimized
  • Throttle Booster
  • Spark Timing Advance/Retard - Y
  • Part-Throttle Shift Points - Superchips Optimized
  • In-Cab Monitoring
  • Idle RPM - Y
  • Fuel Rich/Lean Adjustment - Y
  • Data Logging - Y
  • Check Clear DTCs - Y
  • Calibrate Speedo for Tire Size - Y
  • Accepts Custom Tunes from CMR - Y
Swerve19
