AFE Momentum GT Cold Air Intake System in Raising Hell Red at Got Exhaust
AFE Momentum GT Cold Air Intake System in Raising Hell Red w/ Black Pro 5R Filters​
Make the baja-bred powerhouse 2021–2023 RAM TRX stand out with aFe Power's Momentum GT Intake System, finished in Raising Hell Red. Delivering the same performance gains as the Momentum GT line, this model kicks it up a notch with a bold, aggressive look that will make the engine bay a showstopper. The striking red color and Black Pro 5R filter demand attention, making sure everyone knows what's under the hood. With this intake system, not only will the RAM TRX pull harder and faster than ever before, but the intoxicating supercharger whine will be even more pronounced than stock. Don't settle for subtlety; take the TRX to the next level with the Momentum GT in Raising Hell Red.
  • Dyno-Proven Gains up to +28 HP and +25 Lbs. x Ft. TQ
  • Outflows Factory Intake by 30%
  • Measured Flow: 715 CFM @ 7" H2O
  • Durable Red XLPE Construction and Sealed Housing Protects From Impact, Extreme Temperatures, and Other Elements
  • Washable and Reusable Black Oiled Pro 5R Air Filter for Maximum Performance
  • Innovative Filter-to-Housing Interface for Easy Installation
  • Massive Clear Sight Window for Convenient Filter Inspection Without Disassembly
  • Sealed Housing Incorporates Factory Hood Inlet Scoop and Grille Air Inlet
  • Premium T-Bolt Clamps and a Silicone Couplings Provide a Secure Seal and Excellent Durability
Raising Hell Red:
You don’t drive a Baja-bred, powerhouse like the RAM TRX to blend in. That's why the Momentum GT, finished in Raising Hell Red, is perfect for those who want to stand out even more. With the same performance gains as the Momentum GT line, this model takes it up a notch with a bold, aggressive look that will make your engine bay a showstopper. Its striking red color and Black Pro 5R filters will demand attention, making sure everyone knows what's under the hood. The red model of Momentum GT intakes is exclusively available on select platforms, so you can be sure your TRX will be truly one of a kind. With this intake system, not only will your TRX pull harder and faster than ever before, but the intoxicating supercharger whine will be even more pronounced than stock. Don't settle for subtlety; take your TRX to the next level with the Momentum GT in Raising Hell Red.
Dual Five Layer Performance Air Filters:
A pair of 360-degree radial flow air filters feature our pre-oiled Black Pro 5R media with five layers of progressively finer cotton gauze media for maximum performance. Our Pro 5R media provides your engine with the largest amount of high-flowing air, usually resulting in the highest power gains out of all other filter media options. This media is perfect for street use. The inverted tops make for more filter surface area, resulting in longer service intervals.
Filter-to-Housing Interface:
Momentum’s innovative filter-to-housing interface was built to feature the largest air filter possible. Once the system is installed, the air filters can be easily removed from the housing for maintenance by only uninstalling the side intake tubes.
Unique One-Piece Housing:
The smooth one-piece sealed housing, constructed of heat-resistant red cross-linked polyethylene (XLPE), features our patent pending filter-to-housing interface. Its innovative design minimizes the total number of parts, making for an easy installation. A massive clear sight window allows for hassle-free filter inspection without having to disassemble your intake system. The housing incorporates both the factory hood air inlet scoop and the grille inlet using no additional hardware.
Dyno-Tuned Intake Tube:
This system features a trio of high quality, computer-designed, dyno-tuned intake tubes to achieve maximum power gains while maintaining a perfect fit. Our XLPE material is heat soak resistant and extremely durable.
Premium Components:
Stainless-steel T-bolt clamps are included for strength, and a premium silicone coupling allows for ample flexibility and durability. Momentum GT intakes are designed with fewer parts for a fast and easy installation.
Message me for a quote
Beer Money
Florida
Raising Hell Red:
Premium Components:
How much $$$?
wings
