Nat.G
I saw on social media that Gas Monkey Garage got a brand new 2023 TRX and upgraded the rear suspension with a Foutz Motorsports Hydraulic Bump Stop kit with a 1" rear Spring Spacer lift kit.
If you do some serious off-roading in your TRX, this kit will for sure soak up the biggest bumps when you rip thru the trails. I agree with the Gas Monkey guy in this video, this bump stop kit is pretty badass.
Check it out
www.foutzmotorsports.com
Check it out
2021 - UP Ram TRX Rear Bump Stop Kit with Hydraulic Bump Stops - by Foutz Motorsports
Upgrade your off-road experience by conquering the trails in a whole new way with this TRX Hydraulic Bump Stop Kit Adding the hydraulic bump stop improves the ride in rough terrain. Uses a 2.5" diameter bump stop with 2.5" of travel to soak up the biggest bumps with ease. Installs in the...
