Digital Rearview Mirror
Great, Hopefully @OnTheReel can help us with this.
Can’t help too much on this one. But if the photos are to be believed it sure looks like this one has the extra button:
Only thing is that it’s NOT listed for full speed forward collision warning equipped trucks (like the TRX). This one is but you can’t tell by the pics if it has the extra button:
Detox
Dubai
@OnTheReel Thank you, that is great info. I will head to the dealer and try to see if they have them in stock, maybe I can check them out if they do.
Will share more info.
Detox
Dubai
A bit more information from the RAM HD forum team, there is an extensive group discussion about this subject but no clear decision/direction yet. Here are main points and the link:
- The Digital Rear View Mirror (DRVM) system is completely separate to the 360 degree camera system and they don't share any cameras.
-The Ram HD came with 2 systems, one like ours in the TRX and another better one with the Tri view display.
- The Tri view display mode on the DRVM is based off rear facing cameras on the side mirrors on the HD not TRX hence for this retrofit to work we need to figure out a way to get compatible cameras and have a clean mounting solution.
- All the Cameras are connected to a signal processor under the driver seat with one output to the Mirror itself.
-The coaxial cable connection to the mirror carries the display, power and control signals.
So we still need to confirm the correct part number and thanks to @OnTheReel for making it easier now.
And confirm the PN of the under seat signal processor for the Tri view mirror.
More info to follow as we find out more.
JettaBrook
