TRX weight
And itnlooks like 1400lbs payload. Different axels than a 1500?
Wow that is pretty heavy. That is around power wagon weight which is a 2500
DiabeticSith
Texas
According to the AutoBlog tester:
EXTERIOR
Length 232.9 "
Body width 88.0 "
Body height 80.9 "
Wheelbase 145.1 "
Ground clearance 8.0 "
Curb 6,396 Lbs.
Gross weight 7,800 Lbs.
AXLES
Front 215 (8.5)
Rear 256 (10.1) Dana 60 with available open, limited-slip, or electronic locking differential
Available Ratios 3.55
So my 2020 Limited has a 7100lb GVWR and with 3900l front and 4100lb rear GAWR. Wondering how the TRX compares
DiabeticSith
Texas
The TRX has a GVWR of 7800 lbs.
Front Gross Axle Weight Rating of 4300 lbs.
Rear Gross Axle Weight Rating of 4200 lbs.
Why they do not put those axles on the standard RAM and bump the payload. The whole payload game is a ruse
KarmaXiong
